Vibration Please Help
I have a 99' Z28 with 41k, I just bought it a few weeks ago. I have a vibration that I think is coming from the rear, I had the tires rotated and balanced. All tires balanced out good and had a tread depth of 8 out of 10 so the tires are practically brand new and in good condition. I can not feel any flat spots on the tires or any signs of cupping. When I leave in the morning and the tires are cold I can really feel what would be a flat spot at just 5 mph and below. When the tires are warm I do not feel it unless above 80mph. Is this a tire issue or could some old shocks and springs cause this as well as I am sure with the low miles on the car they were probably never replaced.
Thanks for the help!
Scott
Scott
Originally Posted by 6spdpewterZ
Check your driveshaft, make sure its balanced or that it does not have play.. That happened to me and ended up being just unbalanced rear tires.
Well the tires have been balanced.....but would I feel the drive shaft at 5 mph or less and then really not feel it strongly again until around 80??
