very starange problem...trip OD zeros out and RPM guage goes nuts at startup
Old 01-30-2005, 12:53 PM
Kick_Ass_99SS's Avatar
Question very starange problem...trip OD zeros out and RPM guage goes nuts at startup
K guys, just bought this car and new to LS1s.....
I start my car and the trip odometer zero's out virtually every time. In addition to that, the RPM gauge jumps up to red line, falls back down to 0, and then jumps around between 500-1500 RPMs or about 10 seconds before finally setlling around 700-800 RPMs, which is what it normally idles at. The engine does not seem to be doing the same thing though, the engine sounds smooth with no change in idle even while the RPM gauge is going nuts.
Sounds electrical to me....anyone have a similar experience?
Old 01-30-2005, 12:56 PM
ULTIMATEORANGESS's Avatar
i had the same problem.my gauge cluster was replaced under warranty and its been fine.
Old 01-30-2005, 01:01 PM
Danny2tek's Avatar
Theres a TSB for 99's about this. Mine did the same thing and I replaced the battery and terminal connections (they were corroded) and ever since then its been fine.
Old 01-30-2005, 01:33 PM
SSCam99's Avatar
Exact same here. Had it replaced and no problem since.
Old 01-30-2005, 02:37 PM
Copy & Paste Moderator
VIP1's Avatar
Some people on here have experienced this and almost always its a low battery. Corroded connections/terminals can contribute as well. Replacing the gauge cluster masks the low battery problem because the later clusters had something built-in to compensate for it (I don't remember exactly what they did, probably involving capacitors).
Old 01-30-2005, 03:02 PM
brad02somss's Avatar
I had a similar problem but it was because the wire was rubbin against a belt and it sorda like ate through it a little bit it affected the rpms and how fast i was going, i wouldbe a t a dead stop going 70 mph, maybe ur wires are touching a belt and it rubbing it ??????
Old 01-30-2005, 03:13 PM
cool thanks guys ill take a look at all of that.
Old 01-30-2005, 04:01 PM
Zymosis's Avatar
same prob on my 99
I just decided to deal with it after I made sure it wasn't the battery.
Old 01-30-2005, 05:14 PM
i replaced the battery...lets see how it goes...i did shut it down and start it once and it sticked (the mileage on the trip odometer). strangest thing though...the power seats stopped working after changing the battery?????
Old 01-30-2005, 05:54 PM
Full-Force's Avatar
my 99 does the same thing .... i have found out with the help of ls1tech that its common on 99's
Old 01-31-2005, 03:02 PM
Christos's Avatar
My 99 does the same thing.
Old 01-31-2005, 03:08 PM
it seems replacing the battery did the trick for me...no probs since then...will post if something occurs....thanks guys.
Old 02-01-2005, 12:51 AM
Toadman's Avatar
I went to start the car today and the car wouldn't turn over since the battery is dead from the cold we been having. After I took the key out the speedo went to 90mph and everything else went up and the went back to zero. I thought it was kinda odd until reading this post. Have to wait to spring to get a battery.
Old 02-01-2005, 01:50 PM
Phoenix 5.7's Avatar
bad battery. go with a optima IMO
Old 02-02-2005, 09:57 PM
Full-Force's Avatar
Q: Why does the trip odometer on my 1999 F-body sometimes reset back to 0 during cold weather? I know I didn't reset it.
A: There is a Technical Service Bulletin that you can refer to when taking you car into the dealer for it. Apparently its something wrong with the gauge cluster on the 1999s only. The TSB number is 99-08-49-009. The problem only exists when the car is cold and the battery drops below approximately 85% normal operating voltage. This causes the instrument cluster to reset itself. The regular odometer is not affected, and no other areas of the car are affected.
Old 02-03-2005, 08:04 AM
i actually just looked at teh TSBs and I did not see one for it...but was skimming through fast..I'll have to ake another look when I get a chance....but I don't think there were any.
Old 02-03-2005, 02:34 PM
Blue Hawk's Avatar
https://ls1tech.com/forums/general-maintenance-repairs/247122-trip-odometer-resets-startup-sometimes.html
Quick Reply: very starange problem...trip OD zeros out and RPM guage goes nuts at startup
