668.3 HP From Chev 377"!!!
The dyno sheet from this Dart Alluminum Block engine. 10.8 compression, 18 deg Chapman 246 cly heads, titanium valves, comp cs254/260 R108 roller cam, .026/.028 valve lash, 93 octane, Penzoil 15w-40 mineral oil, Accel 416 plugs .040 gap, 1 7/8 headers, 750 Holley Carb. 668.3 Hp Non blower or turbo.
See dyno sheet at: http://community.webshots.com/photo...233855104KcyjkN
Forgive my ignorance, but how is The builder of this engine (American Speed) getting these numbers, and nothing like it in this forum?
2005 GTM
2005 GTM
Gtm
I am triing to get more input, not enough action on the other thread. The GTM is C5 base Kit Car nearing production at 2200 lbs.
See www.factoryfive.com
GTM Prototype #2
Not available yet. Factory Five Racing (FFR) have taken 2+ years in development and hundreds of thousands of dollars. Production will begin this Spring for previous FFR owners. Kit starts at 20k then add the wrecked C5.
I think there are some cars like that on this forum. But a Dart Al block sound like a BBC to me. Any idea on displacement?
American Speed
Stroked small block (sbc not ls1) BFC (big ******* cam) and some really nice flowing 18* heads. And an intake that will support that power. Very costly which is why you don't see that much around here. Considering heads/cam/header + bolt-ons with a LS1 can get you over 500bhp for way less.
i looked at that engine and basicly its a no expense spared motor
its not that hard with a monster cam like that with those heads, titanium valves, dry sump setup, etc ... its perectly balanced im sure and its probably running a little on the loose side
if its a 400 destroked to a 377 then its got about a 4.125 bore which will unshroud the valves and allow bigger valves and let them flow nice
Originally Posted by technical
668bhp is roughly 568rwhp (15% drivetrain loss).
Not very hard at all. We have 4.030 bore motors doing that and for half the price. Have a 418 Windsor Ford that makes that (685 @ 7000) for less than half too! They are using 18 degree chevy heads which can make 800 or more on a larger engine with more compression. It's all in the cylinder heads.
We've got a naturally aspirated inline six cylinder making 640hp in one of our cars, makes 2.47 hp per cube. We have a no expense spared 440 small block going together right now, Pro Topline heads, titanium rods, etc that will make over 900 hp N/A. 660 from a 377 is pretty stout but nothing extraordinary.
Aaron's motor was a budget build as well!
