Fuel pump removal
Fuel pump removal
Allright, I had my friend install my racetronix pump while I was deployed he did the trap door method.when he put the pump back in he messed up my fuel sender in the process ,but he got the pump in. When I got back I decided to take it out and see if there was something I could fix but there wasnt and when I went to put it back in I must have done something to the fuel pressure regulator or put a hole in the return plus it was hard as hell to get the whole assembly back in. I have a 98 so I know its harder then the 99's and up. I found a whole fuelpump and sender on ebay. My question now is should I try the trap door method again or drop the tank. I just dont wont to f-up the new sender.
