Can't figure out this problem
I went to the track last weekend and ran the new cam with some mickey thompson et streets. I rolled through the water, then spun out real good. When I finished the burn out I pushed in the clutch and pull the car out of gear. The idle rpm stuck at or around 2200 rpm for over a minute. Something froze up in the system. I rode the clutch up to the starting line and then mashed the gas a couple of times and it came back down to normal idle. Does anyone have any idea what caused this or what happened?
