Loctite on heads install?
I'm about to put my heads on and have arp head bolts. My question is should i use loctite? If so red or blue? Also, should i use anything when i'm installing my katech rod bolts on stock rods? TIA
~Rob
~Rob
Supposed to put moly lube on the ARP headbolts before install so you get proper torque readings. I dont remember ARP saying any locktite was recommended. ARP actually lists 2 different torque settings depending on if you use moly lube or motor oil to lube the threads.
