one minute it is fine the next its trying to die on me....
Old 02-10-2005, 07:04 PM
riceyum's Avatar
Default one minute it is fine the next its trying to die on me....
I dont know what is wrong with my car, i came home and started it and it was fine then i went to the mall and came out and it was running like crap sounded like it was missing or something, so i try to get home and i have the throttle down to where it would normally be at 4000 but it is at 1500 then it just cleared out when i gave it a little more and i was fine, but it does this every time it has been run and you start it again. it sounds like it is missing but if you gag it, it will clear out sometimes and run good, sometimes it takes a couple of times, it feels like everyother cylinder is hitting. I dont know what is wrong it just started doing it and my wife is about to kill me. please help.
Old 02-14-2005, 01:55 PM
pwrtrip75's Avatar
ttt. mine does the same thing once in awhile. whats weird is if i disconnect the O2 sensor its fine, but will die at idle once in awhile. i posted this similar question a couple weeks ago. no one replied.
Anyone?? any suggestions?
Old 02-14-2005, 02:10 PM
P Mack's Avatar
Do you have a log of it doing this?
Old 02-14-2005, 03:59 PM
WS6snake-eater's Avatar
Sounds like an o2 problem...ck for burnt wires.
Old 02-14-2005, 04:07 PM
Cal
Cal's Avatar
My wife's car was doing this, so I changed the O2 sensors and it still did it, so she was about to kill me also! Check your fuel presure; her car ended up needing a new fuel pump.
