Fuel- N20 VS FI
True, the extra fuel is used to slow the burn down with pump gas.
If you cool the intake charge down by other means, and run higher octane fuel that will burn slower, then you no longer require so much extra fuel with FI, but fuel delivery capability has to be increased due to the injectors firing into pressurized ports.
