patman help!! need help German castrol
i have a 2001 transam...and ive been running 5w30 and burn about a quart every 3k....
my question is can i switch to german castrol 0w30??? i live in chicago..will that have any bearing on using this oil...i drive my car all year round...
also whaat are the change intervals...??? should i change the filter every 7k ?? wihit oil???
mods in sig.
thanks!!!!!
mods in sig.
thanks!!!!!
There has been a post discussing this for about a week now:
https://ls1tech.com/forums/general-maintenance-repairs/226637-oil-analysis-results-german-castrol-0w30.html
Yes, you can run it. It is a great oil and I am running it in six cars right now. If you find it, stock up. For the first change, I would recommend 5K miles and then send a sample to Blackstone for #46 Terry Dyson analysis. Terry will provide specific advice for your car.
Start out your first run with this oil at 5 or 6k, then send it off for analysis to see how much longer you can go. I ran my first run at 5k, and am about to change it again this weekend, with 6k on it. This summer I will begin to follow my oil life monitor, so I'm expecting it to go as much as 8k.
very cool... what filter would you recommend??? and how often should i change it in the interval?
is mobil one filters any good??? are there longer ones...its such a paiin to change the small ones..(cant get my hands in there!)
thanks guys!!!
thanks guys!!!
That German Castrol 0w30 is hard to find around here. I found 8 qts at AutoZone the other day and bought them all. I changed the oil after and also used the K&N 2006 long filter. I have been using Mobil 1 5w30 with the K&N 2006 filter. Does anyone know of an on-line place that has this oil? The shipping would me.
Bill
Bill
Thanks,
Bill
Where are you guys getting this from. I work as a manager of a lube shop and i called our oil supplier and he told me that they cant get it.I went to autozone and they old me thats just a dealer item. I really want to try this but cant find it.
thanks guys!!!
thanks guys!!!
I recommend the K&N oil filters. You could leave them on for your entire interval, no need to change it partway through. It's good for 10k easily.
is there an order/item # for the castrol 0W30? that way if autozone dosent have it stocked i can have them look up the # and hopefuly have them order some.
can i run the 0W30 year round? temp ranges from as low as 20* in the winter & as high as 100+* in the summer.
Thanks,
stuart
Thanks,
stuart
The folks at AZ generally haven't a clue about what they have on the shelf. There are two kinds of Castrol Syntec 0W30. Both have the same SKU number, so the AZ employees don't know which is there. When they reorder they don't know which they are getting, and generally don't care.
You will have to look at the back of the container. If it says Made in USA, leave it there. If it says Made in Germany, take it home. Castrol insists both types are the same, but if you read the back of the containers the German made oil meets different specifications than the USA made stuff.
The only place it is available in the USA is Auto Zone. No on-line source (unless someone wants to go into business for themselves).
Terry, good to see you made it on here!
Stuart, you can definitely run GC 0w30 in any temperature, from the coldest Alaskan weather to the heat of summer in Arizona. It can handle either temperature extreme no problem.
I've also seen this oil at Advanced Auto parts. It is pretty hard to find though, most of them are the made in the US ones. The local autozones around here though have atleast 6 quarts everytime I go.
Originally Posted by 69_YENKO
i went to autozone last night & they actually had it. i bought all they had(7 quarts) they didnt have the K&N oil filter what is a good alternative to it?
thanks for the help.
Stuart
Stuart
Originally Posted by Patman
Stay away from the Mobil 1 filters, they don't flow very well.
So guys today i stopped off and purchased this oil today with a mobil one fiilter...i guess i should return it and buy the K&N 2006...
Thanks
Louie
