guide lines for porting LS1 heads
Old 02-16-2005, 12:14 PM
Abdullah's Avatar
Default guide lines for porting LS1 heads
any one knows the correct guidelines for porting the LS1 heads? i mean where to port and where to leave the port untouched. i got guidelines for porting LT1 heads and i wonder if the LS1 heads are the same.
Old 02-16-2005, 01:10 PM
PREDATOR-Z's Avatar
No, not the same, and it also depends on which casting of LS1's you port.
Old 02-16-2005, 03:33 PM
xRaTeD's Avatar
Most of you gains I ussually Found in the bowl, Only port in area's where the port is hurting airflow I recommend reading a book on cylinder head porting From the powerpro series of books..
