Compression ratio???
Old Feb 16, 2005 | 02:52 PM
Smoke T/A's Avatar
Default Compression ratio???
Trying to figure out my compression ratio.
I have a 3.905 bore. stock graphite gaskets(97-98), stock 5.3 heads (unshaved) and diamond flat tops #11502 with a -2 cc reliefs and 1.315" comp height.
Thanks in advance.
Joe
Old Feb 16, 2005 | 02:55 PM
jrp's Avatar
jrp
SN95 Director
~11.0
Old Feb 16, 2005 | 03:02 PM
Smoke T/A's Avatar
Originally Posted by jrp
~11.0
Thanks but can you show me the process you used to come up with that number? I just want to know how to calculate it for myself next time.
Thanks
Joe
Old Feb 16, 2005 | 03:16 PM
jrp's Avatar
jrp
SN95 Director
3.622
61cc
.048
3.910
-.008
-2cc
is what i entered into a CR calculator
Old Feb 16, 2005 | 03:23 PM
1FASTLS's Avatar
taking your bore and if your heads are 68cc head, gasket thickness is 0.040, head gasket volume 7.85cc, piston down bore @ tdc is 0.00 you should be close to 10.37 compresion ratio. Hope this helped
Old Feb 16, 2005 | 03:27 PM
jrp's Avatar
jrp
SN95 Director
your way off, 5.3's have a 61cc chamber unmilled. stock deck height is pistons out the hole .004 - .008 (-.008 per GM).
Old Feb 16, 2005 | 03:47 PM
slow ride's Avatar
Thanks
Joe
How about H.V.+S.V. divided by H.V. = C.R. Good Luck Read sticky above by Tin indain post number 26 has better info.
