Wiring question? battery in rear on LT1
The LS1 cars have a distribution thing right there on the fuse box that you need to connect to. The LT1 cars don't have it there. The only distrabusion block I can see is on the Passenger side strut hump. The LS1 cars have one wire that comes out of the wiring harness that is black. LT1 cars have many and are red.
Soooo....Is this were I should connect to instead of the fuse? I bet there is a power wire from that block directly to the fuses through the wire harness.
If you have any info I'd appriciate it. This is the link to the diagram I been looking at.
http://memimage.cardomain.net/member_images/12/web/696000-696999/696560_58_full.jpg
thanks
thanks
