Sponsored by: DashLynx
Removing Rear Seats, Seat Belt Problem
Old 02-17-2005, 04:34 PM
99Ws6TransAm's Avatar
Default Removing Rear Seats, Seat Belt Problem
Seats are a breeze to break loose..But my problem rests in the shoulder bracket the seat belt goes threw on the back. I had the correct bit and everything..and 2 outta the 4 just stripped instantly. Is there anyway to get the seat belt threw that bracket without removing the brackets? The only thing im thinking is to cut it.
Old 02-17-2005, 04:59 PM
LS1_SS's Avatar
they make special drill bits that will drill into the bolt and turn it out at the same time, check out sears...
-Nathan
Old 02-17-2005, 05:51 PM
ddelallata's Avatar
that sucks. the problem is that they have a ridiculous amount of blue loctite on them. I took mine out without stripping them though but it was a real pain in the ***.
Old 02-17-2005, 06:50 PM
PewterNHRA2001's Avatar
sorry to say, but i doubt those bits from sears will work this time due to all the lock-tight on the screws...i would say either try cutting a slot on the bolt with a dremel so you can use a screw driver, or just completely cut off the bolt...
Old 02-17-2005, 06:52 PM
darkecho's Avatar
i used a hacksaw and cut a notch...not going to look pretty if i ever put them back in though probably.... i might go loop-less haha....
Old 02-19-2005, 01:05 PM
jdustu's Avatar
i think i used a pair of vise grips....i can't remember, but i got them off without cutting anything......
Old 02-19-2005, 01:08 PM
JackZ28's Avatar
Are you sure you used the exact sized bit? I know it's a little late now, but I thought I was using the correct one, until I tried the next bigger. :oops:
Old 02-20-2005, 06:24 PM
LoudmouthLT1's Avatar
If it stripped you used the wrong size one...torx sizes are odd and barely bigger then one another. Robogrips should get a nice hold on the bolt head though.
Old 02-20-2005, 06:26 PM
Jpr5690's Avatar
i had a simlar prob with my deatbelts i just cut the belt along the stich line if i ever go back ill just get it restiched
Old 02-20-2005, 07:29 PM
Theres really no way to get robo-grips or anything around the head of the bolt. Its recessed in the bracket itself..
Old 02-20-2005, 07:38 PM
Z95m6's Avatar
They do use a crap load of locktite on them. I ended up having to use vice grips to get mine out.
Old 02-20-2005, 07:54 PM
howd you even get vice grips around the bolt? there like flush down with the bracket...
Old 02-20-2005, 08:24 PM
01 Red WS6's Avatar
Ive done the same thing. I stripped out my bolts and used vise grips. Worked out great
Old 02-20-2005, 08:34 PM
whew..i got it.. I pretty much just cut a slot in the brackets to get the seat outta the car...grinded a slot into the head of the bolts..and used a flat head and twisted um out. Thanks guys!
