LS1 Cam Swap With Double Roller
Is there anyway to get the cam sprocket off a double roller without removing the oil pump? I assembled the engine out of the car, now I wan't a bigger cam, kinda don't like dropping the oil pan.
Any input is appreciated.
Joe
Joe
I think you will need to drop the pan... Make sure to losen up the lower trans bolts going into the oil pan and then just take out the pan bolts in the front and lower the pan without completely dropping it to give you enough room to remove the oil pump and swap the double roller in.
Mike
Mike
if ur not changing the lower sprocket u DO NOT need to lower the pan www.ls1howto.com i believe is the website.
I don't think you guys realize how little play is in the double roller. You can't get the cam sprocket (not the lower one) away from the chain cause the chain doesn't bend. I think if you loosened the oil pump bolts, you would have enough play to get it out without having to lower the pan.
Thanks for the input. I assembled and installed the enigne as a small block. I remembered not having any slack at all in the Double Roller chain. Maybe with a few miles on it, it stretched a little?
Thanks, Anthony R. Glad to hear it has been done. Did you have a Rollmaster?
Joe
Joe
Originally Posted by Steve H.
Yes, I just did. Just remove the 3 bolts from the cam sprocket and drop it down. You should plenty of slack in the chain.
Thanks,
Joe
Joe
Joe
Originally Posted by Classic
Can be done, I've done it many many times on my own vehicle without any hassles.
Thanks All.
