handheld custom cam tuning
while i'll agree, you are assuming the person will already have a laptop. no laptop means more money needing to be spent. at least with the VHP handheld, most of the hard work is done for you. all you need to do is just play around with the fuel and timing some to dial in your setup.
Originally Posted by txhorns281
Manipulating the parameters isn't the hard part, having an understanding of what really needs to be manipulated is the key, and handhelds do not give you that.
here's a dyno of my wife's 99 formula i just tuned using the handheld. all bolt ons, + heads, and stock cam. car runs and drives fine. idle is great. no surging, etc...
there may not be one formula to make xxx duration cams to work right. but, like i said, you pick the cam program that fits your cam duration @ .050, then tune from there. the VHP handheld isn't like all the others out there. there were over 28 cars and over 1000 hours used to design the programs in this tuner. these are not generic tunes. they did all the driveability aspects of it. all the idle issues, TM, certain code parameters set far enough as not to trip the SES, etc. not saying there won't be something that you might come across that you might need taken care of that's not addressed by this handheld.
well, apparantly, it took care of the additional airflow the heads provided. the cam will be a cakewalk from here. maybe you should try this handheld before commenting about it. this handheld isn't in the same class as the others. i'd take this over having to spend countless hours tuning with an editor. not saying you won't get better results using an editor, but you'll get better results with this tuner than with any other. 3 hours of dyno tuning trying the different options until max results acheived vs ???? hours dynoing and driving around with an editor or having someone else tune it for you and have to keep going back until finished.
