Routing the Nitrous feed line
How did you guys route your line. I have a 1997 Formula and the bottle inmounted in my spare tire area. Any info pics or anything would be greatly appreciated. thanks
Not sure if yours is the same, but i was able to find a grommet, way up in the top corner on the passenger side. It came out behind the box of wiring right there on the firewall.
His being a 97 and mine a 02, i wasnt sure.
HOWEVER, if it DOES exist, you will probably have to carefully cut the gromet bigger.
That's the grommet where the PCM wiring goes thru. You can do it that way, but if you ever need to pass tech at the track, I don't think that is an approved way of doing it. I ran mine thu a hole I drilled in the spare tire area, facing the gas tank. I used a bulkhead fitting to go thru, then went between the heat shielding and gas tank, over the axle, and followed the brake/fuel lines to the engine compartment.
That's just one more way of doing it.
i think i might go ahead and route it inside the car. i have a few wires to run also and if im going to do that then i can do it all at once. thanks for all the info.
I have no idea how Tech at a track would be able to see that grommet. Mines buried so you cant see the grommet from under the hood, and with alot of the panels removed i still couldnt see it from inside the car. Also my kits completely hidden.
