O2 problem, car has BIG miss
Old 02-21-2005, 07:05 PM
TDSRacing's Avatar
Default O2 problem, car has BIG miss P0161 & P0300
My car has sat several weeks. Now it has a huge miss. We ran the codes on a Delphi system and it said the back bank 2 O2 heater malfunction. It also says multi cylinder miss-fire. The long trim was +15 on one bank and -8 on the other. I replace the O2 and the problem is still there. I used a heat guage for exhaust temps and one side is MUCH colder than the other. HELP PLEASE!!!
Old 02-21-2005, 07:55 PM
horist's Avatar
what are the exact codes? "back bank 2 O2" sounds like passengar rear to me.... which won't have an effect on driving
if EGT is so much higher on 1 side ... I would check those injectors... possibly clogged
what kinda car? year/make/mods
Old 02-21-2005, 09:11 PM
TDSRacing's Avatar
It is a 2001 WS6 TA lid and cat back.
Code DTC P0161 & P0300
Bank 2 had the 17.19 short fuel trim
other side 1.56
Old 02-24-2005, 10:36 AM
TDSRacing's Avatar
other side 1.56
ttt
Old 02-25-2005, 11:28 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'm guessing that the front O2 on bank2 is bad and not reporting accurately. Thus, you are injecting a lot more fuel, and that bank will be considerably colder than bank1.
