T-rex Tunning Emergency Help!!!!!
T-rex Tunning Graph inside 2nd page
Ok here is the deal. I was having problems when in the lower rpms with the car kind of sputtering and almost dying. Well the guys at Mc Racing tell me that it is kind of like it drops a cylinder. I am not real sure how to explain it.
But this is what the dyno Graph is looking like
It pulls to 5800 at 377 horses then flat lines and stays there until 6500 and then noses off. The dyno #'s that they are showing is 377/346 before this cam I put down 346/340. There is obviously a problem. But what is it.
They tuned this cam before with a car and it made over 430 on the same stuff that I have.
i need way more info, what timing, need to see a graph, getting any kr?
i dont know much about them springs, whats the lift and pressrue ratings on them, you may be getting vavle float? cam could be a notch off on the install, ive seen it before, who installed it
fyi, i put down about 430/380 at 5800rpms so you have a problem
I am getting the graph faxed to me now I will try to get it online in a few mins. As far as KR i am not sure to tell you the truth I am not the one doing the tunning but I am gong to try to find out. I don't think that the graph is going to show valve float but again this will be the first time I see it to. The springs are rated to .650 lift and I am using 7.4 pushrods
We installed the cam so as far as a notch off that could be very possible. Can you let me know how I might be able to fix that or some guidence on how to correctly install it.
JPR.....Yeah the cam was driving fine untill I fixed a problem that we were having with the o2 extension. Then all of a sudden is does not run like it was. I asked them if that would have something to do with it but they said that the o2's were reading fine.
i have my springs shimmed for additional seat pressure cause i think mine are only rated for .650 also. but i jacked up the pressure a lil on them.
if none of the easy fixes work, pull the front cover off and make 100percent dam sure you are installed dot to dot on the cam.
and lastly, check your plugs and wire, i didnt notice i had some bad wires till we tried to make a pull right after putting the cam in and it ran like ****, only make like about what your making, 2 bad wires later i was up to 420's make sure they all ohm out to be ok and that you have good plugs, preferably tr6's
and last, i had this problem also, make sure your tb is opening 100% i had those adjustable tcs cables and it wasnt adjusted right to where it hit the stopper
Thanks for the insight I will check on all of these. But these sound like things that would effect top end right or would this affect the way that the car runs in the lower rpms. I am damn sure that dot to dot is lined up correctly but I may take it off just to make sure. They changed the wires and that did not fix the problem. They were telling me that they were going to change the plugs to. We will have to see. I am so con fused the car runs fine after 3000 rpms but that is not going to get me very far if I am sitting at a light next to a cop.
SN95 Director
98's have 28.6# injectors. which springs are you running, like rodney said the cranes need to be shimmed for more seat pressure, that will reduce the lift rating. what was wrong with the o2 extensions? did you check the wires for frays or burns maybe caused by touching a header primary? what was your a/f?
I am not sure what the A/F ratio was I am waiting on the fax but it does not look like I am going to get it today.
Thanks, Jerami.......Well they got the bottom end sputtering fixed it does not do that anymore. Ended up just being a bad 02 sensor. But as far as power it is not getting any better then 377 and 358.
It starts out at 23 degrees timing and got highest #'s at 25 degrees by 2800 rpms. A/f was straight at about 13 I think that is where the line was. He adjust timing up and down and that was the best he could get. He adjusted the a/f up and down and this was the out come. He is telling me there is obviously a problem he tuned a car that had less done on the g5x cam that made 410/389 so what is wrong
