question about VIG 3600
It all depends on your rear axle ratio, the hooking ability of your tire, and track conditions...Normally, the Vig converters don't like to be stalled that high. My application, being a stock motored car, w/3.23's, Vig 3200, and 8.5" ET Drags, likes to footbrake to 1200 rpm and mash the throttle w/flash of the last yellow...This converter flashes to right around 3600 and hits pretty good. I cut consistent 1.67 sixties and found that the best for my combo. Some like to flash this converter from a dead idle off the line,also w/excellent results, if they've got real good-hooking tires. The Vig 3600 will probably flash to around 4000 rpm. Raceweight also plays a role here. I weigh 3550. Hope this helps a little....WJ
