Timing Low at WOT
Old 03-02-2005, 06:27 PM
Silver02Z28's Avatar
Default Timing Low at WOT
My timing drops to 13.5 at WOT and slowly moves up to 18 or 19. For example, the instant I go to WOT, the timing drops and as the RPMs reach redline, it's back up to 18 or 19. I run this test from in third gear 4K RPM until redline. I can't check KR with my software, but I'm sure it is going on. I'm using 91 octane, and I don't know why this has started now.
I have reset my PCM several times. This cures the problem for a while, but the problem returns shortly. I noticed a power loss and decided to check into it. I am throwing p0420 and p0430. I'll be taking the cats off to see if they are clogged. Any other ideas?
Old 03-02-2005, 06:32 PM
horist's Avatar
you sure those are the only codes you're getting? sounds like you're stuck in the Low octane tables...
Though... A clogged cat will kill performance and I suppose cause excess knock since the exhaust gases can't escape fast enough ... which would force you into low octane tables
Old 03-02-2005, 06:50 PM
Those are the only codes. I must be getting knock right at the start. I'm not sure why.
