Head Chamber Question
Old 03-05-2005, 02:41 PM
DVCrazyCamTAWs6's Avatar
Default Head Chamber Question
We All know what cc the heads are that give us our compression. as far as the ls1,ls6,lq4 go heads and the different piston used in the ls1,ls6,lq4's compared to the lq9 as far as piston distance from the deck goes. Now just talking heads are the mills the same, or are they factory milled to acheive these desired CC's on these heads
the reason for on calculating the Valve distance. milling the heads brings the valve closer to the piston, and other methods is less or more cc's of just chamber designs in changing the cc's. so as far as this heads go which is it...
I'd hate to change the heads and end up with clearnce issues with my big
Old 03-05-2005, 03:07 PM
jrp
SN95 Director
jrp's Avatar
i believe there all cast with the desired CC, no mill from the factory deck.
Old 03-07-2005, 06:33 PM
this would be a good thing to know. Changing the compression without bringing the valves closer to the piston
Old 03-07-2005, 08:06 PM
ssheets's Avatar
I was told the valve drop onthe 5.3 heads compared to the 5.7 heads is .030"
Which is pretty close to what you'd have to mill the 5.7 heads to get the equivelent CR (makes sense) the advantage would be the 5.3 will retain the OEM valve geometry and bump the CR.
Don't know about the LS6 or LQ9s
Old 03-08-2005, 04:07 AM
so as far as the 5.3 heads go their milled .030
now we gotta figure out if thats the same that goes for the 5.7 to 6.0 heads
Old 03-08-2005, 10:06 AM
ssheets's Avatar
5.3s are not milled .030, the chamber ceiling is .030 lower. I.E the valve train gemoetry is not .030 lower.
Old 03-09-2005, 12:39 PM
So the distance from surface(deck bottom) to the valve is that same, so it wouldn't change PVC. just differnet chamber. or is the valve lowered .030 with the ceiling like you mentioned and so it would actually bring the valve to the piston closer still with out changing the geometry
basicly i cant change my PVC it has to stay the same or further away. and need to know if changing the heads on my lq4 would effect my piston to valve clearance, or just compression from the 5.7s or 5.3
