abs channel???
Old 03-12-2005, 05:20 PM
KyleSx5's Avatar
Default abs channel???
Is the abs on a 2000 trans am ws6 3 channel or 4 channel?
Old 03-12-2005, 05:55 PM
Ferocity02's Avatar
ABS without Traction control = 3 channel
ABS with Traction control = 4 channel
I think...
Old 03-14-2005, 04:44 PM
boondiggys's Avatar
yea hes right....nother ?>....whats gotta be done to convert a 4 channel car to 3 channel??
Old 03-14-2005, 09:16 PM
Technoman64's Avatar
I do not think that you can convert the car. Other than a new wiring harness and ABS controller. I would imagine it would require changes to the ECM also(just a guess).
I would think that you could change a 3-channel rear to a 4-channel setup by replacing the axles with 4-channel ones(with exciter rings). And also swapping the brake backing plates(4-channel sensors are mounted in the backing plates).
To change a 4-channel rear to 3-channel you would have to have the center housing machined for the sensor. This would be very difficult to do in my opinion(and exspensive).
To check if you have a 3-channel or 4-channel look for sensors in each of the brake backing plates and wires going to them. If there are sensors in the backing plates you have a 4-channel setup.
Old 03-15-2005, 01:06 AM
2MuchRiceMakesMeSick's Avatar
You can run a 3 channel rear in a 4 channel rear. Your BRAKE, ABS INOP, and ASR light will be constantly on. Obviously you will lose ABS and Traction control.
I recently did this in my freinds car and it was fine (except for what I stated above)
Old 03-16-2005, 11:14 PM
boondiggys's Avatar
1 yeaa it looks like imma be loosing my abs for a while, its ok .....like rice said it was fine
2 are the brakes just able to lock up?
