passenger side bank = no fire! help me out please...
hey guys, i just finished up my lifter change (used stock heads/cam) and now my entire passenger side cylinder bank is not getting any fire!
the car runs suprisingly smooth, and the idle does not change at all when you unplug the main coil pack harness from the passenger side valvecover
the fuel injectors also do not seem to be pulsating to the touch like the driverside bank is either.
what could be wrong? anything i can check? i simply unplugged the coil harness and the fuel injectors when i was dismantling everything, never touched the PCM at all.
