fuel filter
If it is a LS1 car their is a small valve on drivers side fuel rail that after takeing off the cap, you can push in and it will bleed presure. In the past I have never let out the FP before changing the filter, I just take it off and what little preasure their is, just disapates through the fittings. good luck
I have a lift at home in my garage, which will no doubt make it easiest, but I haven't done this before and needed to know if there were any tricks I should know about. Thanks though.
Safest way to depressurise the system is to remove the fuel pump fuse, engine will stall after 2-3 seconds.
2nd way you can do is take your gas cap off the fuel neck for a second or 2 until you hear it release pressure.
