Which bottle heater will stay around 1100psi?
I installed my NOS bottle heater a long time ago and removed the sensor or whatever it was that kept the psi only around 900psi. And I knows its not too safe, left the bottle on for too long once and wasted a whole bottle from too much psi. Can I modify my NOS heater to stay around 1100psi?
If not how is DynoTune or NX's bottle heater or is there any better?
thanks
thanks
1 Post
Yes you can modify you heater with a dynotune pressure switch in place of the temp sensor, you will also need an adapter to adapt the 1/8" ntp switch to your 4 or 6an line. http://www.speedshop.org/store/scrip...p?idproduct=43
Here's what I have. http://www.archeat.com/Merchant2/mer...egory_Code=NBH
I have just the 110v plug in type. It will heat my bottle from 500psi to 1100 in less than 5 minutes. I will maintain it as the one I have has a termo.
David
David
thanks guys
Robert, do you know where I can find a part number and pricing? Been searching on http://www.holley.com/nosnitrous/index.html
and cant find it. That would be the quickest fix
I have a cold fusion one and it used to heat to ~1100 PSI when new but now it seems to peak around 900 PSI but I don't have it wired directly to the battery.
I think the Dyno Tune pressure switch is the only adjustable one out there.
Originally Posted by WICKED SS
thanks guys
NOS 95 degree thrmastat
LS1TECH Sponsor
Originally Posted by Robert56
Check out this thread it has all info and is ongoing. I bought a pair of 95 degree'rs for 20 bucks, compare to Dynotune at 119 bucks. your choice.
Dean
Originally Posted by DynotuneN2O
Robert, I checked out the link and I do not see where you can get a complete nitrous bottle heater kit with an adjustable pressure transducer, heater element and everything else needed for installation for $20? Am I missing something??
Dean
Dean
LS1TECH Sponsor
juiSSed1172,
You are right - I just saw in his quote $119 so I thought he was refering to the full kit. Our transducer only is $49.
WickedSS,
This will work for you - it is $49 and we feel the best transducer on the market for this application. http://www.speedshop.org/store/scrip...p?idproduct=43
Thanks,
Dean
WickedSS,
Thanks,
Dean
juiSSed1172,
WickedSS,
Thanks,
Dean
WickedSS,
Thanks,
Dean
Originally Posted by Elite_Hot_Rod
Would you please explain why 1100 PSI is to high? TIA
