Cold Cranking Issue/Tuning?
what a rush!
My Radix'd 6.0 has developed a cold cranking issue. Once fired, it is fine.
It gets hung up on the cranking portion before firing, sometimes requires 2 bumps, this is only a cranking problem and only when cold, any ideas?
Moderator
There are some cranking enrichment terms in the fuel
tabs. I haven't played with them. Do you also have a
big cam with the blower? I suspect the cranking VE
may be pretty depressed if so, and maybe way over-
enriched at cranking?
what a rush!
There is a loud sucking noise, and some stumbling before it actually fires, that sounds rich to you?
