MTI stage 2E head E/I port ratio....
Old 03-26-2005, 09:17 AM
Raise's Avatar
Default MTI stage 2E head E/I port ratio....
well, i just installed my stage 2e heads and stealth 1 cam a few weeks ago. now im kinda regretting not going with a split pattern cam. i calculated my E/I port ratio, and the exhaust flow at .600 lift is only 69%. i was hoping for more like a 75-80% ratio. so anyway, will a cam with a longer exhaust duration/higher lift compensate for the exhaust port's lacking air flow?? i was set on the G1 cam (228/232 .588/.575 113lsa) when i first ordered my heads, but then i decided to go the stealth route for a "sleeper" car. man i am kicking myself in the *** for that anyway, i kinda wanna swap cams now....i just wanted to know if this would be a good idea. opinions/suggestions??
Old 03-26-2005, 09:43 AM
Bo White's Avatar
Yes, a cam can make up for a cylinder heads weakness by timing events cut into the cam. That is part of the advantage of having a custom cut cam. Try the 232/234 XE-R Comp also
Old 03-26-2005, 09:46 AM
LS1 Tech Administrator
Patrick G's Avatar
You need to stop looking at the flow at .600 lift. You're not running a .600+ lift cam. Look at the flow numbers at .300, .400, and .500". Plus, you need to remember that bolting up the stock intake will knock those intake flow numbers down, while your headers will bring the exhaust flow numbers up. See, MTI doesn't publish exhaust flow numbers with a pipe like other MFRs. Don't sweat the cam choice. Your intake to exhaust ratio is probably right at 75-80% with everything bolted up.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-26-2005, 10:05 AM
Raise's Avatar
hmm....actually when i look at the lower numbers, youre right. it is closer to 75%. i still kinda wanna get off this stealth thing though. i will have this car paid off within a year and it will no longer be my daily driver. so i will be able to give up a lil bit of driveability. though i still wanna keep it pretty streetable. anyway, thanks for the wake up there
Old 03-26-2005, 10:11 AM
Bo White's Avatar
I look at average flow numbers myself. Like mine average from .200" to .600" 222cfm on the intake and 162cfm on the exhaust w/o a pipe so that would be 72.9%.
