nitrous gurus please shine in ?????
yesterday i went to the dyno and put down 510hp and 639tq at the wheels and my a/f was all over the place......at 4100rpm i dynoed 510hp with a a/f of 14.2 at 4300rpm hp was 501 with a 13.9 a/f reading then at 5400rpm hp was 460 and a/f was 12.4 to 1 a loss of 50hp as the rpm increases the hp drops also as a/f gets better the hp drops bigtime......this was with a full bottle and bottle pressure was 1050 after a purge.....i will try to post a dyno slip ....what i'm getting to is do you guys think the wideband could of been wrong???? because of how the power realy dropped off....... this was on a stock truck motor with stock muffler no cat
what is your opinion on this dyno run i will try to post it soon.....thanks for any help
Originally Posted by Gustin
Holding the gas pedal down all the way? What does the car do on motor? Is this just a N2O problem?
Sean
Sean
on just motor it made 311hp uncorrected.... 303hp corrected and 338tq at the wheels motor is bone stock only bolt on mod is a homemade intake open exhaust no programmer
i'm not sure why power dropped in the higher rpm the a/f was getting better at 5300rpm a/f was 12.4 to 1
this is a truck not a car........5000 pounds
