whats the diff with the casting #'s
Old 03-28-2005, 06:00 PM
VaNDaL*SS*'s Avatar
Default whats the diff with the casting #'s
I was just curious my heads are 241, and my new set are 8xx cant remember at the time..whats the diff? thanks
Old 03-28-2005, 07:18 PM
mrr23's Avatar
241 were on corvettes and 01-02 f-bodies 853 are 99-00 heads. both LS1 style.
Old 03-28-2005, 07:19 PM
02WS6Bird's Avatar
What they said ^
Old 03-28-2005, 07:21 PM
VaNDaL*SS*'s Avatar
so is there any real difference between the 2? cuz the ones i got from MTI were 853 casting while the ones on my 02 are 241
Old 03-28-2005, 07:23 PM
f-bodman's Avatar
Once they're ported it doesn't matter.
Old 03-28-2005, 07:24 PM
Bad Seller Alert
getlifted's Avatar
If they have been ported, then i beleive it doesn't matter. But if they are stock, i think the 241's-01-02 are better heads.
Old 03-28-2005, 07:25 PM
mrr23's Avatar
according to smokemup.com nothing. http://smokemup.com/tech/ls1.php but, from what i've heard, stock vs stock, the 241 flow better. once ported, all bets are out the window.
Old 03-28-2005, 07:26 PM
Casperws6's Avatar
mines a 2000 ls1 and came stock with 241 heads
Old 03-28-2005, 09:49 PM
mrr23's Avatar
must be a very late 00. because my 00 formula comes with 853 heads.
Old 03-28-2005, 10:10 PM
Tech's Avatar
I've seen both 241 and 853 on 00 f-cars.
Casperws6's Avatar
guess i got a lil lucky
Old 03-28-2005, 10:36 PM
VaNDaL*SS*'s Avatar
also i have heard that right under ur spark plugs on some heads there is a lil triangle. if you have those then your heads are suppose to be stronger. the triangles are a bi-product of how the heads were casted...dunno though thats just something ive heard
Old 03-29-2005, 08:28 AM
GuitsBoy's Avatar
Semi Permanent Mold (SPM) process, as opposed to sand cast heads. Basically, the SPM process turned out more uniform and smoother textured heads.
