What setting does everyone run their rear Hals?
I've tried everything from 1-6 clicks and can't find a good spot. 6 seems too stiff and anything lower than 4 is too soft. What a pain...
What's everyone else running and what are ur 60ft times?
tell me also
I just got a set of coil overs on all 4 corners. i was told 4 or 5 Rr & 1 or 2 Frt.
whent to the track tonight, only got 3 runs & the track sucked ***. 1.93. my best befor was 1.86,need more seat time.
I am in the same boat.
It seams that most that 60's well are running between 4 to 6 in the rear and 2 to 4 in the front. There are so many other things to consider (springs, tire psi, pinion angle, TQ arm location, ect.)
I went out last week for only the second time with the new set and run a best of 1.64 with rear 4 and the front 3.
Also, some will say to run the right rear one click tighter.
4 in the rear is usually the sweet spot on my car, with 1 set up front. Really my car seems to hook on anything between 3 and 6 in the rear and 1 and 3 up front. I would say maybe it's time to focus on the torque arm adjustment. I have not had to play with mine yet but I want to. I still think I should be able to pull a 1.49 out of my setup but the best I have got so far is 1.51 at GIR. I am curious if there is a better setting on my torque arm.
BTW, tires I seem to do best with my QTP's set at 16 to 18.
My fronts are dialed in...I run them @ 3 if i go softer it unloads too quickly. 4 in the rears seems to work the best so far.
I thought people ran the rears between 4-6, but I read that along time ago and wanted to double check.
Thanks for the replies
Fronts at 2 (am actually going to try setting a little higher to 3 or 4 and see what happens), and rears at 6. Cut a best of 1.47 60' And averaged 1.51's. Hopefully my new rear swaybar and lca relocate brackets along with messin with the front shock settings a little will cut that 60' down, cuz i'm initially hooking and then the rear is unloading and blowin the tires off!
Originally Posted by GueSS Who
Rears at 10
fronts at 1 with R-series only.
Best of 1.27 60ft when the front tires actually trip the lights instead of the rears tripping the lights. LOL
