10 bolt + 2600 stall at 1.8str = ?
Old 03-31-2005, 06:45 PM
firechicken2k's Avatar
Default 10 bolt + 2600 stall at 1.8str = ?
so i will have a 3600 stall on a 1.8str.
my tires about to be replaced (almost no tread left) so i am thinking about getting drag radials (nittos) when times comes.
will my rear end hold up? at the moment its a 100% stock (only have weld in sfcs) 2000 ta with 2.73 gears... so.. that + nittos + the stall, will my 10 bolt go boom? or shall it hold up?
Old 03-31-2005, 07:43 PM
Ragtop 99's Avatar
2.73 gears are pretty strong and you'll have a low STR converter so i would not worry about it. A4 rears can run into trouble at the heads & cam power level, mild bolt-ons are rarely an issue.
