9 inch setup questions
Second, when I take it to get the bearings pressed in, what parts will I need to bring with me. Do they just press it on the axel with the basking plates or will they need the housing also?
thanks.
CMC
CMC
CMC
the backing plates have to be put on the correct side and make sure they are facing the right direction, (the e-brake shoes face outward towards the wheel). Then take the axle shafts and plates to a shop to get the bearings pressed on. I took it to a transmission place after calling about 4 other places with no luck, cost me $30
I think you can buy new backing plates so you can keep your old ones but its pretty expensive.
Also, since the passenger axle is longer, I take it the center section has the yoke offset to the drivers side correct?
