nitrous solenoid problem =(
ok well got my bottle filled today from MTI installed it, turned the bottle on, and n20 went through...
had a few leaks..so i turned it off, tighten the leaks, and on the way home i just used the nitrous that ws in the lines to get it cleared....
well got home turned the bottle on again, and now nitrous is going through the solenoid and into my intake, and is now leaking out of the OUT side of the steel braided lines to the TB...
now on my lines, i think they touched a hot wire and grouned out or w/e and now they are burned...at least one of them is....
so now i went to check out the N solenoid and see if it still worked, and it did still make the click noise when you touch pos and neg..
is my noid not closing all the way or do i gave to rebuild it?
and if i rebuild it can i get the seals from MTi?
please letr me know AASAP
thanks
randy
thanks
randy
I done the same thing and let a hot wire touch the braided line and melted a hole in it so I went on line to SummitRacing.com and found the High Pressure Teflon fitting and spliced the hose, Works grate no leaks at all for three years now with up to 1150 psi.a lot cheeper than a new hose and for the silenoid you can take the big nut off the top and remove the coil and remove the center from the bottom and there is the plunger & spring i have found dabry in it, on new kits you need to remove the line and crack the bottle and blow all the dabry out, then install a filter in line as close as you can to the silenoid, because if there is any thing in the line after the filter it will get to the silenoid or stop a jet up.
its a compucar solenoid, im guessing its a few years old....
it does have the NUT at top and has 4 wires comming out of both fuel and nitrous noids....
hey if you have aim man im me really fast Northernlights87
Originally Posted by Randy WS6
just pm me
well spark pplug backed out, need to fix that, then i need to get a bottle heater, cause im only getting 790psi at most!
Randy
LS1TECH Sponsor
Randy, DynoTune has the heaters on sale for $119! Yes a killer deal.
WWW.DynoTuneNitrous.com
Wait till you have 950PSI
Cheers
Dan
Cheers
Dan
