PE table noob question
Old 04-04-2005, 08:49 PM
mos98c2001's Avatar
Default PE table noob question
When does the PCM use the PE table? After a certain % of throttle, or only at WOT? Any help would be appreciated. Thanks
Old 04-05-2005, 08:11 AM
pknowles's Avatar
You go into PE after a certain % of throttle. The % required changes based on RPM.
Old 04-05-2005, 07:59 PM
mos98c2001's Avatar
that is good info. do you know what % for each rpm, or is it an equation?
Old 04-06-2005, 06:36 AM
pknowles's Avatar
On my car (2002 Camaro SS) the stock file enabled PE mode at 64% TP from 0-3400 rpm, 60% TP from 3400-3800, 54% TP from 3800-4200, and 34% TP from 4200-up. Anything above those values puts you in PE mode. Not sure if GM changed this year to year, but that's what my file says.
