fuel trims way + and then go - ???
Old 04-05-2005, 08:27 PM
WS6FirebirdTA00's Avatar
Default fuel trims way + and then go - ???
ok so i went out on a ride and all my fuel trims were showing +4 to +9. after a little bit of driving they started to go back down around -2 to +2. the car was shut off and then sat a little bit and then we went back out. well at first they were really positive again and then they started to go back to normal.
what would cause this? just the car maybe needing to learn a little bit more? the tune was just put in the car today and we drove about 20 min. my only concern is this never happened before, but i figure its just a cold start/learning issue or something. let me know what you guys think
Old 04-05-2005, 10:41 PM
scottyballs's Avatar
how did your 02's look? where they very active? you may want to try the hotter vette 02's
Old 04-05-2005, 11:13 PM
yeah they are active, but the vettes are hotter? i tried to adjust mine for better oscillations. what is the part number for the vettes? and are these the ones that eliminate extentions??
Old 04-06-2005, 02:00 AM
HumpinSS is using them he said they are much more active, not to sure if you do not need extentions but you have them anyway so you should be good there, I too need to pick up a set.. he knows the part# Ill pm him and get it for us I think he said they run about $75 each. at napa..
Old 04-06-2005, 07:36 AM
ok let me know, i think from gm parts direct or sdpc ou can get them for like 120 for both last i heard. but if you can get the gm part number that would be great thanks
Old 04-06-2005, 09:29 AM
here is the Bosch part# 13111 dont have a # for GM
Old 04-06-2005, 04:07 PM
ok ill try to see if i can find one, thanks a lot!
