Patriot Heads w/cam question
Old 04-08-2005, 02:10 PM
Moderator
JayplaySS's Avatar
Default Patriot Heads w/cam question
Hey you guys with the PP LS6 Stage 2's with the 2.05 valves. I want to run a Vinci 232/240 600/600lift BUT.... on a 110 lsa!! WILL IT FIT WITH THE STOCK HEADGASKETS AND WILL IT RUN OK WITH THE 110 LSA??
\ Thanks
Old 04-08-2005, 03:01 PM
leeluther252's Avatar
I have those same heads and I know that tsp's 233/239 601/603 on a 112 will fit and my comp 232/238 595/605 fits.. Im not sure if the lsa makes a different being 110 though
Old 04-08-2005, 03:02 PM
Those heads are stocl deck height so you can actually go to a descent size came over the 226/226 585/585
Old 04-08-2005, 03:08 PM
Moderator
JayplaySS's Avatar
Thanks Leeluther. Hows the streetability compared to the 226. I want to keep it torqey and livable.
Old 04-08-2005, 03:55 PM
It doesnt like to be at a low rpm any more while crusing around but it doesnt bother me too much. the extra power was defenintly worth it though.. now just need to replace these heads at some point
Old 04-08-2005, 09:30 PM
Moderator
JayplaySS's Avatar
Hey, just wait for some boxed LS7 heads off the new ZO6, they are said to flow like 380! C5R intake ports though I think. I'll be in the same boat too. Thanks for the advice!
Old 04-08-2005, 10:09 PM
TVWilkes's Avatar
The LS7 heads have a 2.200 intake valve.This will not work real well with the stock LS1 bore size.
Old 04-09-2005, 11:58 AM
Moderator
JayplaySS's Avatar
Good point.
Old 04-09-2005, 02:46 PM
With such great flow numbers im sure it wont be long before sponsors make the necesary mods to them for use on every day ls1's.
