IAC reads 0 at idle..is this ok?
Old 04-11-2005, 06:48 PM
badass 2002 z28's Avatar
Default IAC reads 0 at idle..is this ok?
The car fires and idles...Idle is a little rough but not too bad. My IAC count reads 0 at idle. Is this ok since the car runs and idles or should I try to bring it back up some? I am also dealing with the low speed cruise bs thou...
Old 04-11-2005, 07:54 PM
MECHAM's Avatar
if you are using the windows version of autotap..there is a bug in it. not sure if they fixed it or not.
u have to go back to version 1.11
Old 04-11-2005, 08:09 PM
I'm using HP tuners scanner. Just to clear things up before anyone asks. The IAC is plugged in, the car isn't surging, no vaccum leaks...and the IAC is working (goes up while driving around, but it sits at 0 at idle)
Old 04-11-2005, 08:12 PM
Another_User's Avatar
The low speed cruise sounds like you really have exceeding what your IAC can compensate for. If your idle goes too high (100 over for a few seconds, I think) then your car will throw an IAC code. You really should try to get it at 40-50 counts. No matter what your idle counts are, throttle cracker will still work as you drive, so yes it should open.
