what puller do i need for stock pulley
Old 04-12-2005, 09:30 PM
Nsty98LS1's Avatar
Default what puller do i need for stock pulley
just like the title says what puller do i need? the one we tried using won't work and i say different people here use the one from autozone. i need to know which one to get so i can get this damned pulley off tomorrow and get the new cam in tomorow night.
thank in advance,
Jason
Old 04-12-2005, 09:35 PM
ArcticZ28's Avatar
Why won't yours work? I just used a regular 3-arm puller and had no problem (other than the fact that the POS was basically welded to the crank and I had to use a rosebud on it to heat it up enough to get it off ).
Old 04-12-2005, 09:38 PM
blkZ28spt's Avatar
I borrowed a nice, strong 3 jaw puller from autozone. For putting it back on (I did this whole thing in a 35* garage) I heated the inner dia of the pulley with a small torch first so it would slide on far enough to get the crank bolt most of the way in.
Old 04-12-2005, 09:57 PM
ArcticZ28's Avatar
Careful how much you heat it though. Heating it reduces the structural integrity. And be especially careful that you DON'T heat the crank very much. That's just bad news waiting to happen.
Old 04-12-2005, 10:08 PM
Krab's Avatar
Just go to autozone and rent a 3-jaw pulley puller from them. Each arm should be about 6" long. Careful with those arms if you're working on your back under the car, they can easily knock out a tooth. Don't ask me how I know...
Old 04-12-2005, 10:32 PM
ArcticZ28's Avatar
Haha, yea... I almost did the same thing when a 3-foot 1/2" breaker bar fell off the crank bolt
8-Pack's Avatar
This is the puller specfic to our engines. Never used it so I cant comment on how well it works, just throwin it out there. http://www.otctools.com/newcatalog/detail.php3?id=350
