LS6 cam w/ 1.8 rockers?
My buddy wants to put a cam in his 00 TA. He doesn't want to be able to hear the cam, so would a LS6 cam w/ 1.8 rockers work? What would be the final lift and duration? Also, what size pushrods would be needed? TIA
~Rob
~Rob
It depends on which LS6 cam he uses.
01 - 204/211 525/525 116. --- final lift would be 556/556.
02+ - 204/218 551/541 117.5 ---- final lift would be 583/573.
I'd go with a MTI Stealth II cam, 224/220 576/581 116. he won't hear it much if at all and he'll definitely see a ton more power than if he went the LS6 cam route.
works fine, i have my shiftpoints at 6200rpm and HP is still climbing, i use the 7.4 pushrods and dual rev springs
UPDATE: it quite rocks, even with conservative timing, it makes so much power i ran out of 26.4# injectors so yea, it's a good little combo
