Help...Flashing SES Light, No code
Since the install I will get a flashing SES light, if I maintain the rpms between 2000 - 2900. If I pass 3000rpms, the light immediately shuts off. If I drop down below 2000rpms, the light will shut off after about 20 seconds.
It does not throw a code.
The P0300 code has been shut off - yet the light still flashes!
Any ideas?
Also, it was just Dynotuned 2 days ago. The Fuel Pressure, A/F, and all other monitors are reading A+. Its not running rich, nor lean, through the entire RPM range.
I'll work with it some more, and see what comes of it all.
A bad misfire usually causes it to flash. However if you have the codes turned off it is not going to set a code. I would pull the plugs and see if you find anything out of the ordinary.
