Cam Swap On Weekend. Will This Lifter Tool Work?
I 've searched for an hour going through all the threads. Finally doing the cam this weekend, I went to the hardware store and the only pen magnets they had were $7.00 each! I bought 2 aluminum rods 1/4" and I'll try those. Some people say the 5/16" doesn't want to slide in one of the holes on some cars, so they had to use the 1/4.
Will I NEED to flat spot the entire shaft? Will the lifters slide past the 1/4" rod? I have everything set, I want this to go smoothly this weekend. TIA
Originally Posted by Droptopws6
I did But it was the actual cam swap tool from Thunder racing
Just swapped my cam a couple weeks ago. I went to hardware store and got 1-1/4" and 1-5/16" wooden dowels. I got wooden dowels because its much eaiser to be able to bend them when trying to put them in the block. Worked fine, there is no way a lifter is going to slide past unless the laws of physics dont apply where your at. Good luck
After reading many posts, I decided to get a 3/16 steel rod for the left side. I then wrapped it in velcro. It was a nice snug fit. I used 5/16 on the right side and it was perfect.
I only got the 1/4" aluminum for both sides. I was mulling over what to do in a store since my thread searching didn't give "perfect" answers. I'm not going to put velcro or anything, I'm just going to slide them in and......
People do the Russian roulette method all the time and my car is low mile so this is more of an insurance policy. I only have a computer at work, and it's 7:00 -I'm out for the weekend, 'll let you know on Monday. WISH ME LUCK!!! Peace.
