Torque converter bolt size for a TCI converter?
What bolt size is used for the TC1 streetfighter converter? The bolts that came with it are bigger than the stock ones and they won't fit through the flexplate. What is the correct size bolt that I need?
the bolt threads into the tc though, not the flexplate, so you need to use the bolts that came with it.....i had that problem with one of my holes, i ended up using a dremel to widen it up a bit...pry not the best way to do it, but it worked for me....
I opened mine in 3 mins using a 5 buck round metal file. just popped off the starter with engine out of car and opened one hole a tiny bit. I had to use 3 washers for TC bolts, i had about a 1/4" gap between flexplate and TC after bolting trans up - hope this is ok and my 3000 stall lockup switch works -
