How much mph do you lose going from DR's to ET Streets?
Like the title says. I was trapping at 110-111 on street tires and Nittos, now with a ported TB and better launch, best I can pull is high 109's. What gives? Does a ET Street really grow that much at the far end of the track?
The DR's are 245/50/16 Nittos, the ET Streets are 26-10.50-16
Any input would be appreciated.
They grow so they effectively remove some gearing on the top end. Will hurt mph but ET should improve with a better 60 ft, unless you were hooking with the Dr's. If you were already hooking then going to the ET streets could actually slow you down a bit but you'd be more consistent.
