Clutch Master Cylinder
Old 04-22-2005, 04:46 PM
blakefire's Avatar
Default Clutch Master Cylinder
Where is the 1998 Trans Am clutch Master Cyclinder located. Thanks.
Old 04-22-2005, 05:14 PM
tim99ws6's Avatar
firewall under the brake booster....
Old 04-22-2005, 05:59 PM
ss rally red's Avatar
And are they fun to change
Old 04-23-2005, 10:52 AM
LS1TECH Sponsor
Steve Burger's Avatar
The first time will take forever to change out the master. Patience and beer help. Pull the coil packs off the valve cover to give you more room.
Old 04-28-2005, 11:21 PM
shanev8's Avatar
also buy two new bolts with washers and a lock nut, get ride of that u bolt. i used a screwdriver to line up the hole and master cylander hole. two people make the job alot quicker!
Quick Reply: Clutch Master Cylinder
