? on installing fuel pressure sensor.
You don't cut the braided line. You need a peice of -4AN line with fittings on both ends. Basicly, you'd take your current fuel line off the rail, screw the manifold for the pressure sensor on to the end of the rail, then re attach your fuel line to that.
Here's a pic of mine to help you understand.
Great Pic. Nice neat install. Mine is a DP system so It won't work off the rail like yours since it's a separate fuel supply but I get the jist of it. Thanks again for your detailed pic.
Ahh, it makes alot more sense now. Did you want to put it at the noid? You could just pick up a female AN coupler and a male/male fitting for the other side so you can run it inline or Summit must have some kind of hose end combo that will work. Does your FP regulator have a pressure port on it that you can put the sensor on.
