Depth of stock 4th gen F body fuel tank?
I'm going with aftermarket gauges in the cockpit and found out the stock fuel level sending unit on 4th gen F bodies is not compatible with aftermarket gauges so I also have to go with an aftermarket fuel level sending unit. Does anybody know exactly how deep in inches the fuel tanks are? TIA
I ruin the end of films...
I can pull one of my old ones down and measure tonight. It's an LT1, but should be the same.
You just need the height straight down or to the lowest point?
Let me know what you go with b/c I'll eventually face the same dilemna.
Yes straight down from where the pump sits. Jazz makes 2 different length sending units for the 0 to 90 ohm senders, 1 is 9" long and the other is 11". Thanks
