Anybody ever gone back to a rubber tranny mount, after running poly?
I have grown tired of the vibration that comes from my poly mount. So I'm looking at going back to my rubber mount, regardless of how often I tear the rubber.
Anybody else done this?
Tom
Tom
I went back to a stock mount after driving with the Prothane for a month. That didn't last long so I tried the Energy Suspension. It was pretty stiff and vibrated at first but after a week, it was pretty close to a rubber mount with vibration. IMO, the ES is the best combo of stiffness and smoothness.
Jason
Jason
leave the poly in, take a strip of rubber, and put it between the trans crossmember and the frame...
this is what Spohn and some other companys do with their crossmembers that soildly mount the TQ arm...
it really reduces the vibrations felt, while still limiting trans movement like a good poly bushing should..
Just had a poly installed and love it; a little more vibration and noise but not enough to lose sleep over, much happier with this than the stock one.
I often reply to this question. Both company’s poly trans mounts are allegedly designed for the LT1, and are a couple of mm's too tall. The top of the trans rubs against the tunnel and transmits a huge amount of noise at 2200 rpm and up.
A fix is to put one fender washer, with a 3/8ths inch hole I think, between the floor and the crossmember, at each of the 4 bolts that hold the trans brace to the floor. This will lower the trans back to stock height and the noise is basically gone.
A slight vibration is normal, but noise like a helicopter going by is not. The poly mount makes a little vibration you can feel through your feet rather than noise, to me, the way mine is set up, and the "rest of the story" is that I used 4 delrin fender washers. Delrin is brand name for a harder and more durable type of nylon. It compresses very little and is a little harder than most polyeurathanes. The theory for using delrin is that by connecting a material different than steel the harmonic vibrations are diminished. A friend of mine makes windsurfing masts and booms so finding delrin was easier than it may be for you. He carved it round on a lathe and drilled the center holes. I think they are 3mm thick. If you want to use a more exotic solution, there is some improvement with delrin washers.
The compressed thickness of the delrin is 2.5mm. The washers are a little under 3mm uncompressed.
The tailshaft of the trans and the pinion snout on the diff should be parallel, so you need to measure their up/down and the side-to-side relationship. My trans was slightly off at the side-to-side too, so I pressed it to the drivers slightly to align it when I bolted it up.
I don't know where you get delrin. It is a trademarked brand name so you could search for it. I would think that someone would make delrin washers. You know what the stock sway bar endlink bushings look like -- the white plastic *****? That's pretty much what delrin looks like, if that is any help.
I did not take the preload plate off or grind the nubs off. I think they are part of the pre-load. Otherwise why would ES go to the trouble of making the bumps? It would be cheaper to make the part without bumps.
i have the ES mount on and it does make quite a bit of noise and i did notice that it is taller than the stocker. I was thinking of taking off the extra metal plate (pre-load spacer) and was debating on grinding off the rubber 'nubs'. If i take of the spacer do i have to grind the nubs off??
thanks
thanks
Originally Posted by rhaig
when i first installed the poly trans mount i put the "preload spacer" in. i vibrated like hell. when you take it out it makes it a lot better
I think my trans mount is shot, and I can't decide whether to get the ES poly bushing or just go back with the stocker. I think the new mount will help out with some of the rattles and banging I'm getting from the trans and rear, but I'd just assume keep from creating new vibrations and noise from a new mount. Does anyone have a definitive answer as to whether it is better to take the preload spacer off and grind the nubs down or just to shim the crossmember? Also, where did you guys get your mount at? I went to Advance and they told me that they didn't have it and couldn't even order it for me.
they wont have it in the computer..
Thanks a lot for the help. I read the install how-to on installuniversity, and I was wondering if I'll be able to do this with just a set of jackstands and a hydraulic jack to hold the tranny. I don't have a set of ramps to drive the car up on; will getting only the front of the car up in the air give me enough to make the swap?
