Those w/FAST 90mm intakes, what all did you clean up? Pics?
Old 04-27-2005, 09:32 PM
9 Second Club NA
Dragaholic's Avatar
Default Those w/FAST 90mm intakes, what all did you clean up? Pics?
Well before I put mine back together, I wanted to know what everyone else has done to their's so that maybe I could go in and do the same. I have smoothed out the lip that sticks out right by the port and I have also cleaned up the lips inside the port where the middle portion meets the bottom portion. On the top portion, there are little marks that run across the the runners in a intersecting way. I was thinking about cleaning those up as it does no sealing whatsoever. I was also thinking about smoothing out the throttle body opening. It too has a lip on it. What do you think? I would like to see pics of before and after pics of places you've cleaned up. Thanks.
