Gears & Axles - Are these teeth too bad for install?
fivepointseven
04-27-2005, 10:07 PM
http://img147.echo.cx/img147/8094/mvc001f7el.jpg (http://www.imageshack.us)
http://img147.echo.cx/img147/8629/mvc002f5jz.jpg (http://www.imageshack.us)
Thanks
mzoomora
04-27-2005, 10:26 PM
That area of the tooth doesnt matter. As long as the contact patch is in good shape you should be good.
My question would be what happened to them? If it was damaged in a car then you may have a hard time setting them up quietly.
Scott@DrivelineSolutions
04-27-2005, 10:30 PM
I would still get a small stone and grind it smooth.
fivepointseven
04-27-2005, 11:58 PM
the sellers claims "This happened from setting the ring gear on
the
pinion gear more than usual, but has no effect on performance."
Is this correct? I just wanna make sure the gears are ok for install and wont hurt anything!
HMFDZ28
04-28-2005, 02:10 AM
were they used, it doesnt look like they have a clean contact area. The only times the area with the chips should be affected is in reverse. Like mentioned Clean them up a little
stoker420
04-28-2005, 08:02 AM
deff stone those areas but I would be concernd about how far those craks go down give it a good inspection for cracks running through the gears
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
