Bolts ons (What to expect)
Location: In the big city of Houston and big state of Texas.
Alright guys here we go. I have a 2000 A4 trans am, with these mods (free ram air mod, mti lid, k&n filter, smooth below, ported mass air, cut-out, flowmaster, and tb bypass.) I ran 12.9 at 107.89 on stock tires.
Now Im installing (Pacesetter lt's, 3in. pacesetter y-pipe, 4in. mufflex exhaust system, dual cut-outs, transgo shift kit, ssf 3500 torque converter and nittos.)
What should I expect with all these mods that Im going to do too the car!!!
Thanks in advance for the input.
4in.
Well I went with the 4in. because I know Im going to go with bigger stuff later on and didnt want to buy two exhaust systems, you know??? Im thinking of a 408ci. Pretty soon. Plus didnt want to drop my car or anything like that. Just want it to run!!!!!
im gonna give u the benefit of the dought and say 12.0-12.2 just cause if u hook and with that 3500 stall u wont need much low end and ur headers will move u top end very well.
Location: Hometown:Mount Carmel, IL Current: Las Vegas, NV
Quote:
Originally Posted by tim99ws6
well. His theory is to increase backpressure, and in effect bring the torqu into a more useable range. 2.5 is probably plenty big enough to flow for bolt-on cars. They trick is the bigger the piping, the less the backpressure, the slower a car "feels".....it actually will increase Hp by freeing up backpressure, but with a larger piping, you'll lose some bottom end tq. That's why some guys think that when they open their cutout, their car "feels" slower, but in actuality, you're just sacrificing bottom end torque for top end hp.
The guys theory in effect has some merit, but i seriously doubt he'd be "doing you a favor" by dumping a 3" exhaust for a 2.5 exhaust!
I think youve got the jest of it, but backpressure is not what helps you out, its exhaust velocity. Kind of like over porting a head can kill velocity and hurt power, too big an exhaust can theoretically do the same. Its the reason stepped headers and merge collectors exist. Bigger isnt always better when youre trying to eek out every last possible ounce of power. The slightly smaller 2.5" pipe will boost velocity without creating too much backpressure. The added velocity will create a stronger scavenging effect as the pulses go through the X pipe and down each leg of the exhaust. In order to run at optimum, you shoudl run the smallest pipe without building backpressure. That will keep velocity up and will increase torque everywhere, not just down low.
What does all this mean in the real world? Probably nothing. Any change between 2.5" to 3" pipe would be well within the dyno's margin of error, as well as within any drivers variance. The guy isnt necessarily trying to screw you over, but he is a little irrational about how much it will help you (not likely any at all)
thats is quoted from another thread going on. read the part about velocity. take what you may from that. but 4 inch just seems...how do i put...excessive
I mean will the 4in. drop my performance or will it be the same of a 3.5? What do you'll think? Thats about the only thing thats wrong with what im going with remember I will also have my dual cut-outs. I was planning on putting that exhaust in for sound and performance, you know.
4in.
Another thing the tubes are 3in. the muffler is 4in. sorry if I got people confused. So do some of you'll still think that its to big????
ya your prob going to need to get a 12 bolt rear end to replace our stock 10 bolts. If you have sticky tires that 10 bolt might not hold up. I would say you will be at around 12.3-12.5
